Could someone help me with some ideas about cad designs on the robot?
I use Fusion 360 to CAD all of my robots. You can get it for free from Autodesk if you are a student. It has a bit of a learning curve to it but itβs relatively easy to use.
Here is a link for a tutorial on how to use Fusion 360β¦
CAD Tutorial for VEX Robotics - YouTube
Hope this helps!
Thanks men, Can I contact you if I need help?
Check out this thread. Learning CAD
Yes if you need help just reply to this forum.
Inventor is also a great solution, similar to Fusion 360. It is purely based off of preference.
If your team is higher level, inventer or fusion are better for you, but my lower level team is getting great use out of Protobot. (Though it is only for windows) Hope this helps!
