CAD Files for Pneumatic Cylinder Mounting Brackets
Does anyone have CAD files for the two brackets used to mount pneumatic cylinders? There doesn’t seem to be a file for either of them on the CAD wiki, and a forum search doesn’t come up with anything.
https://vexforum.com/attachment.php?attachmentid=6316&d=1340410626
I have looked through all the CAD libraries that I have and cannot find these parts in any of them :frowning:
I quickly made one up in rhino of the one with the “sticky up” bits, you can get it here-
https://www.dropbox.com/s/srijmq3a3cw3k99/part1.stp
I don’t have the second one at home with me so i don’t have the dimensions :frowning: if you could get the dimensions i could make that one up too :slight_smile:
DISCLAIMER: I measured with a ruler, so its not exactly precise :stuck_out_tongue: i probably should have got the calipers out…
EDIT: I accidentally made a new post instead of editing… sorry
I just made the one in the bottom right of the picture (thats all I could find at home) it is an inventor ipt file and I used calipers to get all the meausurements :stuck_out_tongue:
Link
Great minds think alike :wink:
I just made my own custom ones. Much better I think :smiley:
Thanks for the reply! I would post the measurements for the second bracket or make it myself, but I do not have access to either of the brackets.
would you mind sharing this with us?
When he said “made his own” I think he made he made his own as in out of either plus gussets, pillow bearings, plastic block etc. (So not the official parts).
I could be wrong…
~George
I will when I get into CAD again.
They are from the plastic block, but nonetheless is all still possible in HS if you think about it a bit.
I will post soon.
  • Andrew
In Free Range we also use other parts to mount our pistons from. There are loads of different options out there. Sometimes it is nice to create a custom piece, partly so it is perfect for the design, but also for the sense of accomplishment, even if it is something really simple. :smiley:
~George
We’ve added these STEP files to the VEX CAD Wiki page under VEX Miscellaneous Metal Components.
