Calibrate of inertial sensor
If I want the robot to go straight line from A to B in auton, and then go straight line from B to C, and then go straight line from C to D, I will calibrate inertial sensor for two seconds at beginning in order to go straight line from A to B. Should I calibrate another two seconds for another two straight lines?
No, you only need to calibrate the inertial sensor when the program starts
