Calling motors at the same time C++
I am having trouble calling all motors (spinning motors all at once) in my 6-motor drivetrain at the same time during the autonomous period in C++. My code so far is:
void autodrive(){
L1.spinFor(reverse,600,degrees)
L2.spinFor(reverse,600,degrees)
L3.spinFor(reverse,600,degrees)
R1.spinFor(reverse,600,degrees)
R2.spinFor(reverse,600,degrees)
R3.spinFor(reverse,600,degrees)
I then call it but it moves every motor individually.
Someone else had a similar issue before read this post
It has to do with passing a parameter called waitForCompletion and setting it to false.
Thank you so much! This was really helpful!
