Can a V5 controller be linked to an EXP brain?
Yes, this is possible. both systems are designed to work together, and the process is pretty much the same as linking a V5 controller with a V5 brain.
Thanks. I just figured out how to do it. I simply had to plug the V5 Robot Radio into the EXP Brain.
You can either use a V5 VEXnet radio and pair in the same way as V5. Alternatively switch the V5 controller to bluetooth and use the internal EXP radio, pair the controller with smart cable in the same way.
