Can anyone help me about my code?
My code should work on paper, but on robot. Pulling joystick back doesnt make car go back and X button doesn’t work
#include "vex.h"
#include "math.h"
int direction = -1;
#define directionleft = directionType::fwd;
#define directionright = directionType::rew;
void function(void){
  direction = direction * -1;
controller console = controller();
motor leftMotorA(PORT20, ratio18_1, false);
motor leftMotorB(PORT3, ratio18_1, false);
motor_group LeftDriveSmart(leftMotorA, leftMotorB);
motor rightMotorA(PORT4, ratio18_1, false);
motor rightMotorB(PORT5, ratio18_1, false);
motor_group RightDriveSmart( rightMotorB, rightMotorA);
int main() {
  while(1)
    if (console.Axis3.value() != 0 or console.Axis2.value() != 0)
      if (direction == -1)
        LeftDriveSmart.spin(vex::directionType::rev, console.Axis3.value(), vex::velocityUnits::pct);
        RightDriveSmart.spin(vex::directionType::fwd, console.Axis2.value(), vex::velocityUnits::pct);
      else
        LeftDriveSmart.spin(vex::directionType::fwd, console.Axis3.value(), vex::velocityUnits::pct);
        RightDriveSmart.spin(vex::directionType::rev, console.Axis2.value(), vex::velocityUnits::pct);
    else
      LeftDriveSmart.stop();
      RightDriveSmart.stop();
Welcome to the forums!
Can I assume that this isn’t the code that you’re actually trying to compile? There are multiple things here that should generate errors and prevent the code from actually compiling and loading to the robot.
For instance, the or text between your if conditions should be || to be compliant with C/C++.
or is equivalent to || in modern C++.
Apparently this has been a thing in C++ since 1998: https://en.m.wikipedia.org/wiki/C_alternative_tokens, so not really “modern C++”. Didn’t know that until I saw this code.
This isn’t true, using “or” as an alternative to || is perfectly supported in c++. There may be other issues, but that isn’t one of them.
yep,
#ifndef __ISO646_H
#define __ISO646_H
#ifndef __cplusplus
#define and    &&
#define and_eq &=
#define bitand &
#define bitor  |
#define compl  ~
#define not    !
#define not_eq !=
#define or     ||
#define or_eq  |=
#define xor    ^
#define xor_eq ^=
#endif
#endif /* __ISO646_H */
But I’ve never, ever used them. Most projects have a mixture of C and C++ code and it’s far easier to always just use the originals.
I don’t know, somehow half of the code works
check the ports on the brain, sometimes it helps to switch them. Often the software is correct ant the error is in the hardware.
The reason your X button doesn’t work is because you haven’t programmed it. There is no code saying what should happen when X is pressed.
I dont see a reason why it doesnt detect joystick being pulled back
are you using vex pro, if you are that could be your problem as they discontinued the service in favor of vs code. the platform still works but it is full of bugs and has not been updated since worlds last year.
you could try testing your controller, some of our older ones have malfunctioning joysticks.
Which alternative do you suggest?
It works if I only write the joystick code, but it malfunctions when I add more button functions
I use vs code with git hub as a version control. This is the suggested alternative, and works well when you get accustomed to the new system.
