Milo has been programming in Robot C, but was having trouble with part of his programming. He switched to Vex Code Blocks to make a Programming Skills run, but then the Robot C program that makes the remote work was gone.
Can the brain work both programs, or do you have to choose one or the other?
One or the other, ROBOTC uses all available memory because it uses a virtual machine to run the code. So you can switch back and forward between the two but cannot have programs from both on the brain at the same time.
