…(Im new at the vex forum btw)…
at the end of the match, the robot (and all its mechanisms) should automatically come to a complete stop if there’s nothing wrong with the connection to field control.
also, don’t forget that you can google this too and get the same result. make sure to do a deep google search, look at old posts on the forum, or ask mentors/coaches beforehand.
hope this helps! (◍•ᴗ•◍)
I think SC1 speaks to this as well.
All Scoring statuses are evaluated after the Match ends, once all Scored Blocks, Field Elements, and Robots on the Field come to rest.
a. This rule’s intent is for Driver inputs and Robot motion to cease at the end of the Match, when the
Match timer reaches 0:00. A pre-programmed routine which causes Robot motion to continue after
the end of the Match would violate the spirit of this rule. Any Scoring which takes place after the
Match due to Robots continuing to move will not count
Topic is currently under IQ, so no field control.
@topik Is IQ the correct category or should this be under VRC/V5 ?
