We’re working on our code for states, and wanted to adjust the code so as an example we could move forward while also turning. We’ve struggling to figure this out and as of now our robot can only move forward/backward or turn not be able to do both at the same time. Any help to allow us to do both is greatly appreciated. I attached our code below:
/* Module: main.cpp */
/* Author: VEX */
/* Created: Thu Sep 26 2019 */
/* Description: Competition Template */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// Controller1 controller
// Motor6 motor 6
// Motor8 motor 8
// Motor10 motor 10
#include "vex.h"
using namespace vex;
competition Competition;
//vex::controller Controller1 = vex::controller();
vex::motor backRight = vex::motor(vex::PORT1);
vex::motor backLeft = vex::motor(vex::PORT2, true);
vex::motor frontLeft = vex::motor(vex::PORT3, true);
vex::motor frontRight = vex::motor(vex::PORT4);
//vex::motor middle = vex::motor(vex::PORT5);
//vex::motor lift = vex::motor(vex::PORT6);
vex::motor intake = vex::motor(vex::PORT7, true);
motor_group allMotors = motor_group(frontLeft, frontRight, backRight, backLeft);
motor_group frontMotors = motor_group(frontLeft, frontRight);
motor_group backMotors = motor_group(backRight, backLeft);
motor_group leftMotors = motor_group(frontLeft, backLeft);
motor_group rightMotors = motor_group(frontRight, backRight);
motor_group leftDrive = motor_group(frontLeft, backLeft);
motor_group rightDrive = motor_group(frontRight, backRight);
vex::drivetrain train = vex::drivetrain(leftDrive, rightDrive, 13.3, 17.5, 15, distanceUnits::in, 1.0);
/* Pre-Autonomous Functions */
/* You may want to perform some actions before the competition starts. */
/* Do them in the following function. You must return from this function */
/* or the autonomous and usercontrol tasks will not be started. This */
/* function is only called once after the V5 has been powered on and */
/* not every time that the robot is disabled. */
void pre_auton(void) {
vexcodeInit();
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
void autonomous(void) {
// Insert autonomous user code here.
// allMotors.spinFor(forward, 58, degrees);
/* User Control Task */
/* This task is used to control your robot during the user control phase of */
void usercontrol(void) {
intake.setVelocity(100, percent);
Motor6.setVelocity(60, percent);
Motor8.setVelocity(60, percent);
Motor10.setVelocity(8, percent);
bool taking = false;
// This is the main execution loop for the user control program.
// Each time through the loop your program should update motor + servo
// values based on feedback from the joysticks.
// Insert user code here. This is where you use the joystick values to
// update your motors, etc.
while (true) {
//Backwards
if ((Controller1.Axis3.position() < 0) && (Controller1.Axis1.position() == 0)){
if (Controller1.Axis3.position() < -75)
train.setDriveVelocity(100, percent);
else if (Controller1.Axis3.position() < -50)
train.setDriveVelocity(75, percent);
else if (Controller1.Axis3.position() < -25)
train.setDriveVelocity(50, percent);
else
train.setDriveVelocity(25, percent);
train.drive(forward);
//Forward
else if ((Controller1.Axis3.position() > 0) && (Controller1.Axis1.position() == 0)){
if (Controller1.Axis3.position() > 75)
train.setDriveVelocity(-100, percent);
else if (Controller1.Axis3.position() > 50)
train.setDriveVelocity(-75, percent);
else if (Controller1.Axis3.position() > 25)
train.setDriveVelocity(-50, percent);
else
train.setDriveVelocity(-25, percent);
//Right
else if ((Controller1.Axis1.position() < 0) && (Controller1.Axis3.position() == 0)){
if (Controller1.Axis1.position() < -75)
train.setTurnVelocity(100, percent);
else if (Controller1.Axis1.position() < -50)
train.setTurnVelocity(75, percent);
else if (Controller1.Axis1.position() < -25)
train.setTurnVelocity(50, percent);
else
train.setTurnVelocity(25, percent);
train.turn(right);
//left
else if (((Controller1.Axis1.position() > 0) && (Controller1.Axis3.position() == 0))){
if (Controller1.Axis1.position() > 75)
else if (Controller1.Axis1.position() > 50)
else if (Controller1.Axis1.position() > 25)
else
train.turn(left);
//Backwards Left
else if ((Controller1.Axis3.position() < 0) && (Controller1.Axis1.position() > 0)){
else
else
train.turn(left);
//Backwards right
else if ((Controller1.Axis3.position() < 0) && (Controller1.Axis1.position() < 0)){
else
else
train.turn(right);
//Forward Right
else if ((Controller1.Axis3.position() > 0) && (Controller1.Axis1.position() < 0)){
else
else
train.turn(right);
//Forward left
else if ((Controller1.Axis3.position() > 0) && (Controller1.Axis1.position() > 0)){
else
else
train.turn(left);
//Stop
if (Controller1.Axis1.position() == 0 && Controller1.Axis3.position() == 0){
train.stop();
//Control for intake conveyar belt
//If B is pressed the intake spins, and otherwise it stops
if (Controller1.ButtonA.pressing()){
taking = true;
if (Controller1.ButtonY.pressing()){
taking = false;
if (taking == true) {
intake.spin(reverse);
else
intake.stop();
//lift controls are in the robot configuration menu
Motor6.setStopping(hold);
Motor8.setStopping(hold);
Motor10.setStopping(hold);
//Control for the genral speed of the robot
//Pressing the right button sets the robot to a faster setting
//Pressing the left button sets the robot to a slower setting
//Stops the drivetrain and middle motor when there isn't any input
wait(15, msec); // Sleep the task for a short amount of time to
// prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
//ompetition.autonomous(autonomous);
// Run the pre-autonomous function.
pre_auton();
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
edit: code tags added by mods
