Hello fellow VEX users. I was wondering if for a project I could use just a vex 2-wire 393 motors, without using a microprocessor of any sorts, and if I can just use it as a normal motor with the use of only a battery. Thanks!
The 393 motors can be powered with a 9-volt battery if you have the 9-volt to 2 wire adapter
Well, can it work with 8 double A batteries or less?
yeah a 9-v battery with the adapter works. you could use AA batteries, but you’d probably have to solder on an adapter to a AA battery holder thing.
also why 3 posts? this creates lots of spam, one is suffice.
https://vexforum.com/index.php/36875-can-vex-motors-be-used-with-just-a-battery
https://vexforum.com/index.php/36876-can-vex-motors-be-used-with-just-a-battery
You can also hook multiple 393s to a circuit board and power them that way it you choose
