this is the message i am getting when I try to start the intelitek easyC for Vex controller program.
i am using an AMD turion 64 notebook with dual core and windows vista home premiun 32-bit…so is there a solution to this problem?
thanks for any help!
While easyC has been tested with Vista and appeares to work. Intelitek does not officialy support Vista at this time. The error you are recieving is due to an incomplete install. I recommend you uninstall and reinstall easyC as it usually fixes the issue on XP machines.
