tfris
November 9, 2015, 10:18am
1
Here’s the code. The problem has been simplified to one IME 339 motor. Only one I2C IME 339. IME double blinks green every 3 seconds. But cannot read the encoder counters in the sensors debug window. Any ideas?
#pragma config(Sensor, I2C_1, R_IME, sensorQuadEncoderOnI2CPort, , AutoAssign)
#pragma config(Motor, port1, R_Motor_FW2, tmotorVex393_HBridge, openLoop, encoderPort, I2C_1)
//*!!Code automatically generated by 'ROBOTC' configuration wizard !!*//
#pragma DebuggerWindows("debugStream") // open debug stream window at runtime
task main()
wait1Msec(2000);
//resetMotorEncoder(R_Motor_FW2);
nMotorEncoder[R_Motor_FW2] = 0;
motor[R_Motor_FW2] = 50;
while (1) {
clearDebugStream();
writeDebugStreamLine( "Encoder Cnt : % d ", nMotorEncoder[R_Motor_FW2] );
writeDebugStreamLine( "Time 1ms cnt : % d", nSysTime);
wait1Msec(50);
tfris
November 9, 2015, 2:54pm
2
Will have to try tonight, but I think this is the problem…
You need a special gear with an optical pattern on it:
http://www.vexrobotics.com/encoder-modules.html
In a pinch, you can cut these out and glue them on the 393 gear with the IME:
http://content.vexrobotics.com/images/products/accessories/276-1321-Replacement-Wheel-20150518.pdf
Try moving clearDebugStream () ahead of your while loop;)
I agree, I don’t think you will have enough time to see the debug streams results because they are erased every iteration of the loop. Try this:
task main()
wait1Msec(2000);
// Clear the debug stream
clearDebugStream();
while (1) {
wait1Msec(50);
tfris
November 10, 2015, 8:39pm
5
The optical pattern glued to the internal motor gear fixed the encoder problem. Previous user of the motor must of have had a heck of a time getting the encoder to work
The clearDebugStream() inside the while loop is to keep the stream window from scrolling down quickly with appended new lines of text. It works well so far.
