Ken1
March 28, 2019, 8:34am
#1
I’m trying VEXcode with my laoptop(Win8.1 OS) today and got an error at the first step, I opened a sample program(nothing changed)and click on the biuld button, then I got error message as below screenshot:
It can’t create the directory build/src, I uninstalled VEXcode and reinstall it again, build the program, got the same error still. Then I switched to another laptop(Win10 OS), do the same operation, it can build the program successfully.
Not sure if this is only my laptop issue, or a VEXcode bug with Win8.1.
Any suggestion?
Natic
March 28, 2019, 10:29am
#2
Create a folder in your project folder called build. It should work after you do this.
Ken1
March 29, 2019, 1:42am
#3
Yes, it works! Thanks! though I have to create a build folder whenever create a new project:joy:
It’s a known bug when you have perhaps other unix like tools installed on the PC, we should have this fixed in the next preview due out next week.
I did this and I still get the same error. Does anything have to be in the folder?
Natic
April 6, 2019, 5:43pm
#6
Are you on vexcode preview 2
what is that. Is it another version of vex code?
is it the update? If it is, yes I’m on it.
Natic
April 6, 2019, 5:49pm
#9
Yes the building error was fixed in it. Preview 1 projects still have the issue but if you copy over your code it should fix your error.
I wrote the code while in preview 2.
Natic
April 6, 2019, 5:50pm
#11
Have you tried making a new project and copying over the code?
Yes I have. I added the empty build file, but once I tried building it, it removed the folder from the project folder
Natic
April 6, 2019, 5:51pm
#13
Hmm interesting @jpearman any ideas?
does anything go inside the build folder?
if you could try the following.
edit the makefile and set VERBOSE=1
# VEXcode makefile 2019_03_26_01
# show compiler output
VERBOSE = 1
click build
cut&paste the contents of the output window into this topic. It should look something like this.
[info]: Project Path: /Users/james/Documents/vexcode-projects/Example1_events
[info]: Saving Project ...
[info]: Project saved!
unix build for platform vexv5
mkdir -p "build/src" 2> /dev/null || :
CXX src/main.cpp
clang -target thumbv7-none-eabi -fshort-enums -Wno-unknown-attributes -U__INT32_TYPE__ -U__UINT32_TYPE__ -D__INT32_TYPE__=long -D__UINT32_TYPE__='unsigned long' -march=armv7-a -mfpu=neon -mfloat-abi=softfp -Os -Wall -Werror=return-type -fno-rtti -fno-threadsafe-statics -fno-exceptions -std=gnu++11 -ffunction-sections -fdata-sections -DVexV5 -Iinclude -I"/Users/james/Documents/code/VEX_repos/advanced-cpp-editor-beta/Tools/sdk/vexv5/include" -I"/Users/james/Documents/code/VEX_repos/advanced-cpp-editor-beta/Tools/sdk/vexv5/clang/7.0.0/include" -I"/Users/james/Documents/code/VEX_repos/advanced-cpp-editor-beta/Tools/sdk/vexv5/gcc/include" -I"/Users/james/Documents/code/VEX_repos/advanced-cpp-editor-beta/Tools/sdk/vexv5/gcc/include/c++/4.9.3" -I"/Users/james/Documents/code/VEX_repos/advanced-cpp-editor-beta/Tools/sdk/vexv5/gcc/include/c++/4.9.3/arm-none-eabi/armv7-ar/thumb" -c -o build/src/main.o src/main.cpp
LINK build/Example1_events.elf
arm-none-eabi-ld -nostdlib -T "/Users/james/Documents/code/VEX_repos/advanced-cpp-editor-beta/Tools/sdk/vexv5/lscript.ld" -R "/Users/james/Documents/code/VEX_repos/advanced-cpp-editor-beta/Tools/sdk/vexv5/stdlib_0.lib" -Map="build/Example1_events.map" --gc-section -L"/Users/james/Documents/code/VEX_repos/advanced-cpp-editor-beta/Tools/sdk/vexv5" -L"/Users/james/Documents/code/VEX_repos/advanced-cpp-editor-beta/Tools/sdk/vexv5/gcc/libs" -o build/Example1_events.elf build/src/main.o --start-group -lv5rt -lstdc++ -lc -lm -lgcc --end-group
arm-none-eabi-size build/Example1_events.elf
text data bss dec hex filename
6876 1100 1064276 1072252 105c7c build/Example1_events.elf
arm-none-eabi-objcopy -O binary build/Example1_events.elf build/Example1_events.bin
[info]: build completed!
[info]: download
[info]: download completed!
‘make’ is not recognized as an internal or external command,
operable program or batch file.
[error]: make process closed with exit code : 1
I get this error now^
Hi!
I have the same issue on my laptop. When VEX developers will fix it?
tfriez
April 8, 2020, 6:17pm
#19
I’m not sure which issue you’re referring to… also this is a year old thread, please start a new one if you’re running into issues.
