Catapult Coding
Hello.
So i have built a catapult using 4 speed motors, much like the wingus and dingus catapult.
Questions about the code
When I pull back, I put 127 on the motors, but what power do I use to make the catapult stay back there so I can load? Do I still use 127?
When I release the catapult, should i put -127, or just 0? Thanks!
Well to hold it in place assuming no elastics 0 should do just fine. If you have elastics try holding it back with a little bit of power. I would be afraid of going more than let’s say 20 power or the motor will stall and trip the PTC. To shoot different distances try firing forward at different speeds. 50 90 127 would be some good examples.
