Catapult hitting drivetrain
The catapult is hitting the drivetrain. Being the newbie that I am, I don’t know how to fix it. Pictures below
When you insert your drive train, be sure to make the sprocket close the the catapult and the wheel on near outside.
Try adjusting the position of the axle that holds the catapult to the structure of the robot (raising it up). You can also try adjusting other things as you see fit.
A picture/video of it actually hitting the drivetrain would be helpful.
I am confused, where is the drivetrain?
Also, quick question, where do you get those gears, aside from the gen 2 kits.
The blue or purple gear?
I don’t really know. I just got them from my robotics club head coach. She said that they were special gears. I think you can search it up on Robot mesh
They are 48 and 16 tooth gears and found on the vex store.
You can buy them from VEX here: 24 & 48 Tooth Gear Pack - VEX Robotics.
Correction, 48 and 24 tooth gears.
