My team is using 84 tooth gears included in this kit
http://www.vexrobotics.com/products/accessories/motion/276-2169.html
we need chain for our gearing ratio, which chain should we buy?
A link would be ideal.
Your link refers to spur gears rather than sprockets. Spur gears can’t be fitted with chain, while sprockets can. In addition, I don’t think there are 84-tooth sprockets, so you will have to rethink your ratios if you need to use sprockets/chain. Here are the relevant links:
[Low Strength Kit
High Strength Kit](http://www.vexrobotics.com/products/accessories/motion/276-2166.html")
Additional Low Strength Chain
Additional High Strength Chain
Thanks that was precisely what I needed
If you are still working on gear/chain ratios, take a look at this page, and scroll down to “Links”.
