I noticed some teams are able to score 3 balls at the bottom of Goal E by first forcefully shoving a second ball between the two lower rings. However:
Rule G19 says: ‘The bottom opening of Goals between the lowest two rings has a dimensional tolerance of -0.0 / +0.5”’
Appendix A (field specs) says:
Ball diameter 6.3 +/- 0.1
Center goal distance between bottom rings: 6.5 +0.5/-0
By the above, maximum ball diameter is 6.4" and minimal gap between the 2 bottom rings of Goal E is 6.5" (don’t forget that -0", can make it wider, but not narrower). So there is a 0.1" gap between ball and rings openings that should let the ball go in and out freely and not allow it to be jammed in.
Thoughts?
