i’m trying to find a cheaper battery option for vex, i’ve looked at cheaper NiMH batteries for RC cars. however, i am unsure what charger i should get inorder to match the vex power pack, or whatever battery i am using
unfortunately i doubt you’ll be able to find a suitable replacement for the vex batteries, at least not for a significant amount cheaper
remember, if you do find one it is very important to make sure it meets and does not exceed the current and voltage requirements
i suggest searching the following sites:
www.jameco.com
www.robotshop.ca
www.hvwtech.com
[www.sparkfun.com
hope i helped! :D](www.sparkfun.com)
I agree. If you do find a cheaper set of (quality) batteries, please post back here with details.
You might want to read this thread started by stampede_dude. He did some analysis and found the Vex batteries to be higher quality than most, so they may be a better value than they appear based on price alone.
Here are a few options from Radio Shack for you to look at:
[LIST]
*]Transmitter battery & charger (9.6V, 1000mAH, NiCd, $16) 23-342
*]Transmitter battery & charger (9.6V, 1600mAH, NiMH, $20) 23-432
*]Robot battery & charger (7.2V, 2000mAH, NiCd, $20) 23-322
*]Robot battery (no charger) (7.2V, 3300mAH, NiMH, $25) 23-319
[/LIST]
I’ve used the first one on the list and it works just fine. The other ones look like they should work with Vex and seem like reasonable values.
Cheers,
- Dean
thanks fro teh help, i think i’ll stop by my local radio shack for the 2 batteries, and hopefully save some money
Alternatively you can also assemble your own batt pack. For the vex microcontroller you can use 6 to 8 cells (Well the vex pack is 6 cells but 8 works too). Used to have some 10Ah D sized cells lying around…
I’m not sure I would use homemade battery packs, that sounds like a recipe for disaster…
yea never ever solder batteries
i’ve tried, its a recipe for disaster
