Clarification on GPS Strip Placement Relative to Alliance Side
I understand that the order of the GPS strips is consistent based on the instructions to install new, and the pre made setup for portable fields. My question is whether the setup stays consistent to the field. Essentially if blue starting line is next to side 1, will it always be next to side 1, or could the event potentially set it up in reverse?
The field setup requires the GPS to be oriented in a specific way. If you look at the field specification portion of the manual, the 0 degree location is noted on multiple diagrams.
If an event sets up its skills field incorrectly, you should inform the EP and offer to assist correcting the error.
Match fields are not required to have GPS.
There is a set pattern for the “GPS” strips. They will be the same match to match across the season.
