Clarification on Rules
Hi all,
I wanted to see if someone could clarify some of the following scenarios. It would be much appreciated!!
If the robot is touching their Skyrise at the end of the match, which pieces do not count? If there were 6 Skyrise pieces together, would the whole Skyrise be discounted or just one section?
Same scenario above but with cubes - which pieces would not receive points?
Also, for autonomous, if we have an LCD screen, are we allowed to hit a button on the screen to activate our autonomous after autonomous period has started?
Thank you!!!
I only know the cube situation the one you are touching does not count but only if it the same color as you.
Okay thank you. To add to that is the other alliance allowed to place their cubes on your Skyrise?
No they can’t place their cubes on your skyrise.
The rule is quite specific in terms of interaction:
It does not mention anything about being allowed to press buttons or use the LCD, and this only during driver control, there is no interaction allowed in autonomous.
