Currently for my autonomous, I want to exit my P loop with a timer that lets the robot oscillate/adjust itself within a period of time. Is there a function or a way that allows me to clear the timer in pros?
bool timerClear = true; // continues to clear timer until error is small
if(error1 < 7 && error2 < 7 && error3 < 7 && error4 < 7) {
timerClear = !timerClear;
if(timerClear) {
// clears timer
bool timeClear = true;
int now = pros::millis();
if(error > 10) {// if the robot isn't close to desired target -> clear timer
timeClear = true;
if(timeClear) {
now = 0;
if(error < 10) {// if the robot is close to desired target -> start timer
timeClear = !timeClear;
This is not the best implementation of a state machine but for two states that are within other code running its at least readable:
// pseudo code
start_time = 0;
state_wait_until_close = 1;
state_timeout_when_close=0;
error = <set point> - <current point>
while ( abs(error) > ERROR_MAX_ALLOWED) {
// when error is close, set the current time for use with the timeout
if ( state_wait_until_close && (abs(error) < ERROR_GETTING_CLOSE) ) {
start_time = pros::millis();
state_wait_until_close = 0;
state_timeout_when_close = 1;
// timeout if PID is taking too long and is close enough
if ( state_timeout_when_close && pros::millis() > start_time + CONST_TIME_LIMIT) {
state_wait_until_close = 1; // may or may not be needed based
state_timeout_when_close = 0; // on if you use this code again w/ init vars
break;
<PID STUFF>
pros::delay(20);
