Clutch build anomaly (step 39)
Clutch build: Am confounded by the instructions for building Clutch. In the manual at stage 39 one is asked to join the 60 tooth blue wheel to the previously built assembly, specifically a 2 X 16 beam. The diagram shows the four pegs from the wheel(s) snapping in the four endmost holes. But the placement of the pegs on the wheels do not correspond to the openings on the 2 X 16. Please advise.
If you look at the gear, there is a position that it works, rotate the gear some. You’ll find the four holes that line up.
Thanks I’ll try that.
