Code builds correctly, but nothing runs
Using vexcode and had a prefetch error before, then ran into this now. I am just confused at the moment.
#pragma region VEXcode Generated Robot Configuration
// Make sure all required headers are included.
#include <stdio.h>
#include <stdlib.h>
#include <stdbool.h>
#include <math.h>
#include <string.h>
#include "vex.h"
using namespace vex;
// Brain should be defined by default
brain Brain;
// START V5 MACROS
#define waitUntil(condition)                                                   \
  do {        \
    wait(5, msec);                                                             \
  } while (!(condition))
#define repeat(iterations)                                                     \
  for (int iterator = 0; iterator < iterations; iterator++)
// END V5 MACROS
// Robot configuration code.
triport Expander = triport(PORT20);
// AI Classification Competition Element IDs
enum gameElements {
  mobileGoal,
  redRing,
  blueRing,
controller Controller1 = controller(primary);
motor Left1 = motor(PORT1, ratio6_1, true);
motor Left2 = motor(PORT2, ratio6_1, false);
motor Left3 = motor(PORT3, ratio6_1, true);
motor Right1 = motor(PORT13, ratio6_1, false);
motor Right2 = motor(PORT16, ratio6_1, true);
motor Right3 = motor(PORT6, ratio6_1, false);
motor Intake_default = motor(PORT15, ratio6_1, false);
// AI Vision Color Descriptions
// AI Vision Code Descriptions
vex::aivision AIVision19(PORT19, aivision::ALL_AIOBJS);
inertial Inertial_Sensor = inertial(PORT10);
digital_out Mobile_Goal_Piston = digital_out(Expander.A);
motor ArmThing = motor(PORT17, ratio36_1, false);
// generating and setting random seed
void initializeRandomSeed(){
  int systemTime = Brain.Timer.systemHighResolution();
  double batteryCurrent = Brain.Battery.current();
  double batteryVoltage = Brain.Battery.voltage(voltageUnits::mV);
  // Combine these values into a single integer
  int seed = int(batteryVoltage + batteryCurrent * 100) + systemTime;
  // Set the seed
  srand(seed);
void vexcodeInit() {
  //Initializing random seed.
  initializeRandomSeed();
// Helper to make playing sounds from the V5 in VEXcode easier and
// keeps the code cleaner by making it clear what is happening.
void playVexcodeSound(const char *soundName) {
  printf("VEXPlaySound:%s\n", soundName);
  wait(5, msec);
// define variable for remote controller enable/disable
bool RemoteControlCodeEnabled = true;
#pragma endregion VEXcode Generated Robot Configuration
/*    Module:       main.cpp                                                  */
/*    Author:       {author}                                                  */
/*    Created:      {date}                                                    */
/*    Description:  V5 project                                                */
// Include the V5 Library
#include "vex.h"
// Allows for easier use of the VEX Library
event message1 = event();
competition Competition;
int AIVision11_objectIndex = 0, Brain_precision = 0, Console_precision = 0, Controller1_precision = 0;
float myVariable, ArmDegree, MobileGoalPiston, TolerenceTime, X_axis, Y_axis, Error, InitialPlace, DistanceNeeded, Integral, prevError, Derivative;
bool test;
bool Intake_vari;
bool Intake_vari2;
bool AButton;
bool ArmFlipFlop;
motor_group RightSide(Right1, Right2, Right3);
motor_group LeftSide(Left1, Left2, Left3);
smartdrive Drive(LeftSide, RightSide, Inertial_Sensor, 260, 380, 385, mm, 1.67);
//(distance * 360) / (wheel circumference * gear ratio)
//so (distance * 360.0) / ((PI * 3.25) * (36.0/60.0))
// 12 inches equals about 705 degrees needed
// "when autonomous" hat block
int onauton_autonomous_0() {
  InitialPlace = ((LeftSide.position(degrees) + RightSide.position(degrees)) / 2);
  DistanceNeeded = 1350 + InitialPlace;
  while (true) {
    Error = DistanceNeeded - ((LeftSide.position(degrees) + RightSide.position(degrees)) / 2);
    Integral = Integral + Error;
    if (Error == 0 or Error < 0) {
      Integral = 0;
    if (Error > 1350 or Error < -50) {
      Integral = 0;
    Derivative = Error - prevError;
    prevError = Error;
    RightSide.spin(forward, Error * 0 + Integral * 0 + Derivative * 0, volt);
    LeftSide.spin(forward, Error * 0 + Integral * 0 + Derivative * 0, volt);
    if (Error < 10 && Error > -10) {
      TolerenceTime = TolerenceTime + 15;
    } else {
        TolerenceTime = 0;
    if (TolerenceTime == 45) {
      break;
    wait(15, msec);
  Mobile_Goal_Piston.set(true);
  Drive.turnToHeading(90, degrees);
  return 0;
// "when started" hat block
int whenStarted5() {
  Intake_default.setVelocity(600, rpm);
  Intake_vari = false;
  Intake_vari2 = false;
  while (true) {
    if (Intake_vari2 == false) {
      //AIVision19.takeSnapshot(blueRing);
    if (AIVision19.objectCount > 0) {
      Intake_default.spinFor(forward, 360.0, degrees);
      wait(0.5, seconds);
  return 0;
int whenStarted6() {
  while (true) {
    if (Controller1.ButtonR2.pressing()) {
      Intake_default.spin(reverse);
      else if (!Controller1.ButtonR2.pressing()) {
        wait(1, msec);
        Intake_default.stop();
  return 0;
int whenStarted7() {
  LeftSide.spin(forward);
  RightSide.spin(forward);
  while (true) {
    LeftSide.setVelocity(Controller1.Axis3.position(), percent);
    RightSide.setVelocity(Controller1.Axis2.position(), percent);
    if (LeftSide.isDone()) {
      LeftSide.setStopping(brake);
    if (RightSide.isDone()){
      RightSide.setStopping(brake);
    wait(15, msec);
  return 0;
int whenStarted9() {
  MobileGoalPiston = 0.0;
  while (true) {
    wait(0.25, seconds);
    if (Controller1.ButtonL2.pressing()) {
      MobileGoalPiston = MobileGoalPiston + 1.0;
  wait(5, msec);
  return 0;
int whenStarted10() {
  ArmThing.setStopping(hold);
  ArmThing.setVelocity(100, percent);
  ArmThing.setMaxTorque(100, percent);
  ArmDegree = 1;
  while (true) {
    wait(100, msec);
    if (Controller1.ButtonL1.pressing() && ArmDegree == 1) {
      ArmDegree = 2;
      ArmThing.spinToPosition(-15, degrees);
      else if (Controller1.ButtonL1.pressing() && ArmDegree == 2) {
        ArmDegree = 1;
        ArmThing.spinToPosition(0, degrees);
    if (Controller1.ButtonR1.pressing() && ArmDegree == 2) {
      ArmDegree = 3;
      ArmThing.spinToPosition(-125, degrees);
      else if (Controller1.ButtonR1.pressing() && ArmDegree == 3) {
        ArmDegree = 1;
  return 0;
int whenStarted11() {
  Mobile_Goal_Piston.set(false);
  while (true) {
    if (!(fmod(MobileGoalPiston,2.0) == 0.0)) {
    } else if (fmod(MobileGoalPiston,2.0) == 0.0) {
  wait(5, msec);
  return 0;
// "when driver control" hat block
int ondriver_drivercontrol_0() {
  while (true) {
      RightSide.setStopping(brake);    }
  return 0;
int driver_control1() {
  while (true) {
    } else {
  wait(5, msec);
  return 0;
int driver_control2() {
  while (true) {
        wait(1, msec);
  return 0;
void VEXcode_driver_task() {
//  // Start the driver control tasks....
  vex::task drive0(ondriver_drivercontrol_0);
  //vex::task drive1(driver_control1);
  //vex::task drive2(driver_control2);
  //vex::task drive3(driver_control3);
  while(Competition.isDriverControl() && Competition.isEnabled()) {this_thread::sleep_for(10);}
  drive0.stop();
  //drive1.stop();
  //drive2.stop();
  //drive3.stop();
  return;
void VEXcode_auton_task() {
  // Start the auton control tasks....
  vex::task auto0(onauton_autonomous_0);
//vex::task auto1(onauton_autonomous_1);
//vex::task auto2(onauton_autonomous_2);
  while(Competition.isAutonomous() && Competition.isEnabled()) {this_thread::sleep_for(10);}
  auto0.stop();
//auto1.stop();
//auto2.stop();
  return;
int main() {
  vex::competition::bStopTasksBetweenModes = false;
  Competition.autonomous(VEXcode_auton_task);
  Competition.drivercontrol(VEXcode_driver_task);
  vexcodeInit();
  //vex::task ws1(whenStarted2);
  //vex::task ws2(whenStarted3);
  //vex::task ws3(whenStarted4);
  vex::task ws4(whenStarted5);
  vex::task ws5(whenStarted6);
  vex::task ws6(whenStarted7);
  //vex::task ws7(whenStarted8);
  vex::task ws8(whenStarted9);
  vex::task ws9(whenStarted10);
  vex::task ws10(whenStarted11);
  //vex::task ws11(whenStarted12);
  while (true) {
    wait(100, msec);
I would try to see if everything is getting to the robot ok
