code help
hello. im working on my robot again, and this time i wanted to have the button that controlled the servo previously directly control the led flash this time. is there a way to make the function loop until the down button is pressed?
task flash2;
task headlight;
task headlight()
while(true)
if(SensorValue[in1] > 400)
motor[port9] = 127;
else
motor[port9] = 0;
if(vexRT[Btn8U] == 1)
motor[port5] = 31;
else if(vexRT[Btn8D] == 1)
motor[port5] = -31;
else
motor[port5] = 0;
if(vexRT[Btn6U] == 1)
motor[port4] = 67;
else if(vexRT[Btn6D] == 1)
motor[port4] = -67;
else
motor[port4] = 0;
task flash2()
while(true)
if(vexRT[Btn5U] == 1)
SensorValue[dgtl1] = true;
wait1Msec(500);
SensorValue[dgtl1] = false;
wait1Msec(500);
else if(vexRT[Btn5D] == 1)
task main()
bLCDBacklight = true;
wait1Msec(10000);
displayLCDCenteredString(0, “Darkez 8.X”);
wait1Msec(10000);
displayLCDCenteredString(1, “ACTIVE”);startTask(flash2);
startTask(headlight);
startTask(flash2);
while(1==1)
motor[port1] = (vexRT[Ch1] + vexRT[Ch2])/2; // (y + x)/2
motor[port10] = (vexRT[Ch1] - vexRT[Ch2])/2; // (y - x)/2
motor[port2] = (vexRT[Ch4]);
motor[port3] = (vexRT[Ch4]);
if(vexRT[Ch1] ||  vexRT[Ch2] == 0)
	SensorValue[dgtl2] = false;
else
	SensorValue[dgtl2] = true;
heres my code. the selection i need help with is task flash2()
Have you tried doing:
while(!vexRT[Btn5D]) {
  //some code
