Code issues #include "vex.h"
I’m trying to use the vex visual studio to write code, however I keep getting this error. Does anyone know how to remedy this?
(here is my code)
#include "vex.h"
using namespace vex;
//#region config_globals
vex::brain      Brain;
vex::motor      Ld(vex::PORT1, vex::gearSetting::ratio18_1, false);
vex::motor      Ld2(vex::PORT2, vex::gearSetting::ratio18_1, false);
vex::motor      Rd(vex::PORT3, vex::gearSetting::ratio18_1, true);
vex::motor      Rd2(vex::PORT4, vex::gearSetting::ratio18_1, true);
vex::motor      F(vex::PORT5, vex::gearSetting::ratio18_1, false);
vex::motor      I(vex::PORT6, vex::gearSetting::ratio18_1, false);
vex::motor      P(vex::PORT7, vex::gearSetting::ratio36_1, true);
vex::controller con(vex::controllerType::primary);
vex::controller con_p(vex::controllerType::partner);
//#endregion config_globals
// Creates a competition object that allows access to Competition methods.
vex::competition Competition;
void pre_auton() {
    // All activities that occur before competition start
    // Example: setting initial positions
void autonomous() {
    // Place autonomous code here
void drivercontrol() {
    int fs = 70;
    int is = 70;
    int ps = 100;
    while (true) {
        Ld.spin(vex::directionType::fwd, con.Axis3.value(),vex::velocityUnits::pct);
        Ld2.spin(vex::directionType::fwd, con.Axis3.value(),vex::velocityUnits::pct);
        Rd.spin(vex::directionType::fwd, con.Axis2.value(), vex::velocityUnits::pct);
        Rd2.spin(vex::directionType::fwd, con.Axis2.value(), vex::velocityUnits::pct);
        if(con_p.ButtonR1.pressing()) {
            F.spin(directionType::fwd, fs, velocityUnits::pct);
        else if(con_p.ButtonR2.pressing()) {
            F.spin(directionType::rev, fs, velocityUnits::pct);
        else {
            F.stop(brakeType::coast);
        if(con_p.ButtonL1.pressing()) {
            I.spin(directionType::fwd, is, velocityUnits::pct);
        else if(con_p.ButtonL2.pressing()) {
            I.spin(directionType::rev, is, velocityUnits::pct);
        else {
            I.stop(brakeType::coast);
        if(con.ButtonA.pressing()) {
            P.spin(directionType::rev, ps, velocityUnits::pct);
        else if(con.ButtonY.pressing()) {
            P.spin(directionType::fwd, ps, velocityUnits::pct);
        else {
            P.stop(brakeType::coast);
int main() {
    // Do not adjust the lines below
    // Set up (but don't start) callbacks for autonomous and driver control periods.
    Competition.drivercontrol(drivercontrol);
    // Run the pre-autonomous function.
    pre_auton();
    // Robot Mesh Studio runtime continues to run until all threads and
    // competition callbacks are finished.
Your code looks like it should compile ok in Robot Mesh Studio V5 C++. What’s the error you’re receiving?
21:31:03 – error – In file included from cxx_entry.cpp:16:
./main.cpp:1:10: fatal error: ‘vex.h’ file not found
#include “vex.h”
and I already tried robot mesh, it compiles fine but doesn’t want to download onto the brain or run a mimic file
@oddshapedcoconut For future reference, see here:
How to format code
I assume you mean Vex Coding Studio
vex.h is not.a valid header file for VCS, usually the C++ source file would include robot-config.h
Yes, I meant the coding studio, and I’ll go give that a try
Ok, that fixed that issue, so thank you. However, it now has this error
22:07:07 – error – In file included from cxx_entry.cpp:16:
./main.cpp:6:17: error: redefinition of ‘Brain’
vex::brain Brain;
./robot-config.h:1:12: note: previous definition is here
vex::brain Brain;
delete the redefinition of Brain in main.cpp
Ok, I did that so now it’s just telling me I’m not connected to the brain (which I don’t have wit me) so I’ll have to test that tomorrow. Thanks for the help, and I’ll probably be back if I have any issues.
