Code not opening
So I’m trying to work on my code but for whatever reason it refuses to even open. what happens is that I try to open it through the web version of VEXcode V5 but for whatever reason it wont open the code or even acknowledge that I tried to open it, the file says that ii opened it in the date modified but VEXcode wont load it. This code is my most important code as it is the only one i have downloaded that is up to date and it also has all of my autons, my custom driver control, the up to date versions of my custom blocks, and lots of other very complicated things that will take me forever to replicate and to make it even worse I have states in 2 weeks and I don’t have enough time to code everything again and still improve my robot before states. Does anybody know how I can fix it? I’ve tried closing the VEXcode tab and using a new one, duplicating the file and using the duplicate, using a different browser, & restarting my computer, yet it still wont open. Every single other VEXcode file on my computer works except this one. So if you have even the slightest idea on how to fix it please tell me ASAP.
use the backup you made, you do have a backup I hope !
otherwise post the file here and I’ll take a look and see what may be corrupted.
So I was doing research and I found another VEXforums post regarding something like this that said you can open the file with notepad so I did. when I opened it with notepad there was nothing in the file so it somehow got wiped so now I have to remake all of my code because I didn’t have a backup because I had my code saved to OneDrive and never considered that my code might get wiped a week before states. But thanks for trying!
