Code working normally but not during competition
The code i wrote works when i do run, and when i do a timed run both autonomous and regular code work. However when i plug in the controller during an actual match the autonomous works but after that only the drivetrain is accessible, the other motors etc dont work. This is incredibly urgent because i will be doing my last 2 matches tomorrow and any replies would be appreciated. Thanks in advance!
Please post your complete program, remembering to add triple backtics (```) before and after your code. Otherwise, it’s very difficult for us to debug code we can’t see.
and perhaps export the project and attach the zip file
New users cant upload attachements :confused:
I’ll send it when i get home, im typing this on my phone and cant upload the zip of the project so ill type the files in about 2 hours. Thanks for the fast reply
main::
/*    Module:       main.cpp                                                  */
/*    Author:       VEX                                                       */
/*    Created:      Thu Sep 26 2019                                           */
/*    Description:  Competition Template                                      */
// Robot Configuration:
// [Name]               [Type]        [Port(s)]
// Drivetrain           drivetrain    11, 1
// Controller1          controller
// KolKaldirSag         motor         2
// KolKaldirSol         motor         12
// KolMotorSag          motor         3
// KolMotorSol          motor         13
// KuleDik              motor         7
#include "vex.h"
using namespace vex;
competition Competition;
/*                          Pre-Autonomous Functions                         */
/*  You may want to perform some actions before the competition starts.      */
/*  Do them in the following function.  You must return from this function   */
/*  or the autonomous and usercontrol tasks will not be started.  This       */
/*  function is only called once after the V5 has been powered on and        */
/*  not every time that the robot is disabled.                               */
int dikPozisyon = 30;
int egikPozisyon = 1;
float kolKaldirSure = 0.6f;
float tumKupSure = 3;
bool teamRed = false;
//KIRMIZIYSAK BUNU true YAP, MAVİYSEK DOKUNMA
void kollariKaldir()
    KolKaldirSag.spin(reverse);
    KolKaldirSol.spin(reverse);
void kollariIndir()
    KolKaldirSag.spin(forward);
    KolKaldirSol.spin(forward);
void kolDurdur()
    KolKaldirSag.stop();
    KolKaldirSol.stop();
void iceriKupAl()
    KolMotorSag.spin(forward);
    KolMotorSol.spin(forward);
void disariKupAt()
    KolMotorSag.spin(reverse);
    KolMotorSol.spin(reverse);
void icKolDurdur()
    KolMotorSag.stop();
    KolMotorSol.stop();
void kuleyiDik()
    KuleDik.spin(forward);
void doksanDereceEg()
    KuleDik.spin(reverse);
void retard()
    KuleDik.stop();
void pre_auton(void) {
  vexcodeInit();
  KuleDik.setVelocity(40, rpm);
  KolKaldirSag.setVelocity(80, rpm);
  KolKaldirSol.setVelocity(80, rpm);
  KolMotorSag.setVelocity(200, rpm);
  KolMotorSol.setVelocity(200, rpm);
  Drivetrain.setDriveVelocity(200, rpm);
/*                              Autonomous Task                              */
/*  This task is used to control your robot during the autonomous phase of   */
/*  a VEX Competition.                                                       */
/*  You must modify the code to add your own robot specific commands here.   */
void autonomous(void) {
  //Drivetrain.driveFor(forward, 100, mm);
  ////Orta açılınca takılmasını engelle
  //kollariKaldir();
  //wait(kolKaldirSure, seconds);
  //kollariIndir();
  //kolDurdur();
  ////Ortayı aç
  //Drivetrain.driveFor(forward, 242, mm);
  //iceriKupAl();
  //Drivetrain.drive(forward);
  //wait(tumKupSure, seconds);
  //Drivetrain.stop();
  //icKolDurdur();
  ////Küpleri al
  //Drivetrain.turnFor(right, 180, degrees);
  //wait(3, seconds);
  //Drivetrain.driveFor(reverse, 20, mm);
  ////Geri dön
  //if (teamRed == true) Drivetrain.turnFor(left, 90, degrees);
  //else Drivetrain.turnFor(right, 90, degrees);
  ////Kırmızı takımdaysak sola, Mavi takımdaysak sağa 90 derece dön
  //Drivetrain.driveFor(forward, 200, mm);
  ////Skor alanına kadar ileri git
  //kollariKaldir();
  //kolDurdur();
  //kuleyiDik();
  ////Kuleyi dik hale getir.
  //Drivetrain.driveFor(reverse, 200, mm);
  ////Kuleyi bırak ve git
  Drivetrain.driveFor(reverse, 1500, mm);
  Drivetrain.driveFor(forward, 1500, mm);
  //if (teamRed == false) Drivetrain.turnFor(left, 90, degrees);
/*                              User Control Task                            */
/*  This task is used to control your robot during the user control phase of */
void usercontrol(void) {
  //Drivetrain.driveFor(reverse, 1500, mm);
  bool ControllerL1R1ButtonsControlMotorsStopped = true;
  bool ControllerABButtonsControlMotorsStopped = true;
  Drivetrain.driveFor(reverse, 180, mm);
while (1) {
    // This is the main execution loop for the user control program.
    // Each time through the loop your program should update motor + servo
    // values based on feedback from the joysticks.
if (Controller1.ButtonL1.pressing()) {
    kollariKaldir();
    ControllerL1R1ButtonsControlMotorsStopped = false;
else if (Controller1.ButtonR1.pressing()) {
    kollariIndir();
else if (!ControllerL1R1ButtonsControlMotorsStopped){
    kolDurdur();
if (Controller1.ButtonA.pressing()) {
    iceriKupAl();
    ControllerABButtonsControlMotorsStopped = false;
else if (Controller1.ButtonB.pressing()) {
    disariKupAt();
else if (!ControllerABButtonsControlMotorsStopped){
    icKolDurdur();
//if (Controller1.ButtonY.pressing()) {
//    kuleyiDik();
//else if (Controller1.ButtonX.pressing()) {
//   doksanDereceEg();
    // Insert user code here. This is where you use the joystick values to
    // update your motors, etc.
                    // prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
  // Set up callbacks for autonomous and driver control periods.
  // Run the pre-autonomous function.
  pre_auton();
  // Prevent main from exiting with an infinite loop.
  while (true) {
    wait(100, msec);
robot-config:
#include "vex.h"
using signature = vision::signature;
using code = vision::code;
// A global instance of brain used for printing to the V5 Brain screen
brain  Brain;
// VEXcode device constructors
motor LeftDriveSmart = motor(PORT11, ratio18_1, true);
motor RightDriveSmart = motor(PORT1, ratio18_1, false);
drivetrain Drivetrain = drivetrain(LeftDriveSmart, RightDriveSmart, 319.19, 370, 244, mm, 2);
controller Controller1 = controller(primary);
motor KolKaldirSag = motor(PORT2, ratio36_1, false);
motor KolKaldirSol = motor(PORT12, ratio36_1, true);
motor KolMotorSag = motor(PORT3, ratio18_1, false);
motor KolMotorSol = motor(PORT13, ratio18_1, true);
motor KuleDik = motor(PORT7, ratio18_1, false);
// VEXcode generated functions
// define variable for remote controller enable/disable
bool RemoteControlCodeEnabled = true;
// define variables used for controlling motors based on controller inputs
bool DrivetrainLNeedsToBeStopped_Controller1 = true;
bool DrivetrainRNeedsToBeStopped_Controller1 = true;
// define a task that will handle monitoring inputs from Controller1
int rc_auto_loop_callback_Controller1() {
  // process the controller input every 20 milliseconds
  // update the motors based on the input values
  while(true) {
    if(RemoteControlCodeEnabled) {
      // calculate the drivetrain motor velocities from the controller joystick axies
      // left = Axis3 + Axis1
      // right = Axis3 - Axis1
      int drivetrainLeftSideSpeed = Controller1.Axis3.position() + Controller1.Axis1.position();
      int drivetrainRightSideSpeed = Controller1.Axis3.position() - Controller1.Axis1.position();
      // check if the value is inside of the deadband range
      if (drivetrainLeftSideSpeed < 5 && drivetrainLeftSideSpeed > -5) {
        // check if the left motor has already been stopped
        if (DrivetrainLNeedsToBeStopped_Controller1) {
          // stop the left drive motor
          LeftDriveSmart.stop();
          // tell the code that the left motor has been stopped
          DrivetrainLNeedsToBeStopped_Controller1 = false;
      } else {
        // reset the toggle so that the deadband code knows to stop the left motor next time the input is in the deadband range
      if (drivetrainRightSideSpeed < 5 && drivetrainRightSideSpeed > -5) {
        // check if the right motor has already been stopped
        if (DrivetrainRNeedsToBeStopped_Controller1) {
          // stop the right drive motor
          RightDriveSmart.stop();
          // tell the code that the right motor has been stopped
          DrivetrainRNeedsToBeStopped_Controller1 = false;
      } else {
        // reset the toggle so that the deadband code knows to stop the right motor next time the input is in the deadband range
      // only tell the left drive motor to spin if the values are not in the deadband range
        LeftDriveSmart.setVelocity(drivetrainLeftSideSpeed, percent);
        LeftDriveSmart.spin(forward);
      // only tell the right drive motor to spin if the values are not in the deadband range
        RightDriveSmart.setVelocity(drivetrainRightSideSpeed, percent);
        RightDriveSmart.spin(forward);
    // wait before repeating the process
    wait(20, msec);
  return 0;
 * Used to initialize code/tasks/devices added using tools in VEXcode Text.
 * This should be called at the start of your int main function.
void vexcodeInit( void ) {
  task rc_auto_loop_task_Controller1(rc_auto_loop_callback_Controller1);
There’s a good chance this line of code at the beginning of user control could cause problems.
if the drive moves under joystick control for any reason before that completes, it will block.
Other than that, I tested on a competition switch and it seems ok.
