Coding 2 V5 controlers to one Robot
Hi, I am from 1930A and we are trying to figure out the coding with two remotes. I don’t know how exactly to do it if it’s just regular and switching out the controller names or if I have to do something else? Can someone help me?
If you are using Vex C++, it should be as simple as dragging and renaming another controller in the Robot tab, and then using the name before any other functions.
thank you so much! this helps alot
you would have your normal controller defined as
vex::controller Main = vex::controller();
then below that you would add another line to define the partner as
vex::controller Partner = vex::controller(vex::controllerType::partner);
you now would code things normally. items run by joystick one would have Main in the front and joystick two would have Partner
ie Main.Axis1.value(); and Partner.Axis1.value();
to actually use the two controllers together you will need to pair the main controller to the brain and then connect the two controllers together using a v5 smart cable, the same type as the motors.
