Hey, I’m new to coding in RobotC so if anyone could help me out I would be very grateful. Any resources, links, or videos that have in depth tutorials for everything from motors to sensors (like gyros) will be greatly appreciated. Thanks!
https://renegaderobotics.org/tag/programming/ is a pretty good opener to how some of the sensors work.
One of our teams is coding in RobotC. they have set up a pneumatics system for their intake and shooter. The problem is that they cannot drive and use the pneumatics? The Robot jitters and the pneumatics pulses ? The 2 pneumatics Solenoids will only work when they are actuated by themselves?
If anyone is willing to have a look at our code that would be greatly appreciated. See below:
#pragma config(Sensor, in1, potmeter1, sensorPotentiometer)
#pragma config(Sensor, in2, potmeter2, sensorPotentiometer)
#pragma config(Sensor, dgtl2, solenoid2, sensorDigitalOut)
#pragma config(Sensor, dgtl3, solenoid1, sensorDigitalOut)
#pragma config(Sensor, dgtl5, AutonomousA, sensorTouch)
#pragma config(Sensor, dgtl6, AutonomousB, sensorTouch)
#pragma config(Sensor, dgtl7, AutonomousC, sensorTouch)
#pragma config(Sensor, dgtl8, AutonomousD, sensorTouch)
#pragma config(Sensor, dgtl9, lEncoder, sensorQuadEncoder)
#pragma config(Sensor, dgtl11, rEncoder, sensorQuadEncoder)
#pragma config(Motor, port1, shooter, tmotorVex393_HBridge, openLoop, reversed)
#pragma config(Motor, port2, frontright, tmotorVex393_MC29, openLoop, encoderPort, None)
#pragma config(Motor, port3, midright, tmotorVex393_MC29, openLoop, reversed, encoderPort, None)
#pragma config(Motor, port4, backright, tmotorVex393_MC29, openLoop, encoderPort, None)
#pragma config(Motor, port5, frontleft, tmotorVex393_MC29, openLoop, reversed, encoderPort, None)
#pragma config(Motor, port6, barlift, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port7, pivot, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port8, midleft, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port9, backleft, tmotorVex393_MC29, openLoop, reversed)
#pragma config(Motor, port10, feed, tmotorVex393_HBridge, openLoop)
//This code is for the VEX cortex platform//
#pragma platform(VEX2)
//Select Download method as “competition”//
//Main competition background code…do not modify!//
#include “Vex_Competition_Includes.c”
//Pre-Autonomous, used for resetting different motors and sensors before the autonomous phase//
void pre_auton()
//Setup for Potentiometers//
SensorValue[potmeter1] = sensorNone;
SensorValue[potmeter1] = sensorPotentiometer;
SensorValue[potmeter1] = 0;
SensorValue[potmeter2] = sensorNone;
SensorValue[potmeter2] = sensorPotentiometer;
SensorValue[potmeter2] = 0;
//Setup for Solenoids//
SensorValue[solenoid1] = sensorNone;
SensorValue[solenoid1] = sensorDigitalOut;
SensorValue[solenoid1] = //0 for close, 1 for open//;
SensorValue[solenoid2] = sensorNone;
SensorValue[solenoid2] = sensorDigitalOut;
SensorValue[solenoid2] = //0 for close, 1 for open//;
//Setup for Encoders//
SensorValue[lEncoder] = sensorNone;
SensorValue[lEncoder] = sensorQuadEncoder;
SensorValue[lEncoder] = 0;
SensorValue[rEncoder] = sensorNone;
SensorValue[rEncoder] = sensorQuadEncoder;
SensorValue[rEncoder] = 0;
// Set bDisplayCompetitionStatusOnLcd to false if you don't want the LCD
// used by the competition include file, for example, you might want
// to display your team name on the LCD in this function.
// bDisplayCompetitionStatusOnLcd = false;
//Autonomous//
task autonomous()
while(SensorValue(rEncoder) < 2)
motor[frontleft] = 100;
motor[midleft] = 100;
motor[backleft] = 100;
motor[frontright] = 100;
motor[midright] = 100;
motor[backright] = 100;
if(SensorValue (rEncoder) == 2)
motor[frontleft] = 0;
motor[midleft] = 0;
motor[backleft] = 0;
motor[frontright] = 0;
motor[midright] = 0;
motor[backright] = 0;
//User Control//
task usercontrol()
while (true)
//Driver Controls////ALL HIGH SPEED//
motor[frontleft] = vexRT[Ch3];
motor[backleft] = vexRT[Ch3];
motor[midleft] = vexRT[Ch3];
motor[frontright] = vexRT[Ch2];
motor[backright] = vexRT[Ch2];
motor[midright] = vexRT[Ch2];
//Motor for Shooter//
if (vexRT[Btn5D] == 1)
motor[shooter] = 100;
wait1Msec(100);
motor[shooter] = 0;
//Solenoid for Shooter//
if (vexRT[Btn5U] == 1)
SensorValue[solenoid2] = 1;
wait1Msec(100);
SensorValue[solenoid2] = 0;
//Motor for Barlift//
if (vexRT[Btn8R] == 1)
motor[barlift] = 100;
wait1Msec(100);
motor[barlift] = 0;
//Motor for Pivot//
if (vexRT[Btn7L] == 1)
motor[pivot] = 50;
wait1Msec(100);
motor[pivot] = 0;
if (vexRT[Btn7R] == 1)
motor[pivot] = -50;
wait1Msec(100);
motor[pivot] = 0;
//Solenoid for Claw//
if (vexRT[Btn6U] == 1)
SensorValue[solenoid1] = 1;
wait1Msec(100);
SensorValue[solenoid1] = 0;
Copy of 5760B Competition Program V.2.c
Displaying Copy of 5760B Competition Program V.2.c.
This is actually something that can’t really be fixed, we used pneumatics in the star-struck game and it did the same thing its just how the robot processes the code. I would honestly avoid pneumatics if i were you there are too many cons outweighing the pros
Please make a dedicated thread for your question in an appropriate channel, making use of the
tag (highlight your code, click the button in the toolbar between the image and quote buttons).
This is a very vague claim that seems quite misinformed.
Upon just a cursory code examination, there a number of things that could be done so that “how the robot processes the code” is exactly how the user intends for the robot to process the code.
I will gladly list some such things in the aforementioned dedicated thread (I will not further the derailment of this thread).
Is there any way to code two motors to run simultaneously in C++ in VCS?
Nevermind
