Made a ouple of adjustments, still nothing. I have Psudocoded the part of my code that holds my lift when I’mnot moving the joystick. Wrote print codes at the ends of each result and nothing displays. Tunning out of ideas. Any help would be great!
void height_up(void) {
i++;
if (i >= 0 && i < 4) {
if (i == 0) {
RLift.rotateTo(double(-129), vex::rotationUnits::deg, double(75),
vex::velocityUnits::pct);
LLift.rotateTo(double(88), vex::rotationUnits::deg, double(75),
Lift.stop(vex::brakeType::hold);
LLift.spin(vex::directionType::fwd, (Controller1.Axis2.value()),
RLift.spin(vex::directionType::fwd, (Controller1.Axis2.value()),
Brain.Screen.printAt(1, 20, "Ground Level/n");
} else if (i == 1) {
RLift.rotateTo(double(-859), vex::rotationUnits::deg, double(75),
LLift.rotateTo(double(787), vex::rotationUnits::deg, double(75),
Brain.Screen.printAt(1, 20, "LOW TOWER/n");
} else if (i == 2) {
Brain.Screen.printAt(1, 20, "MID TOWER/n");
} else {
RLift.rotateTo(double(-1420), vex::rotationUnits::deg, double(75),
LLift.rotateTo(double(1370), vex::rotationUnits::deg, double(75),
Brain.Screen.printAt(1, 20, "TALL TOWER/n");
else {
i--;
void height_down(void) {
i--;
if (i == 0) {
} else {
else {
i++;
Controller1.ButtonUp.pressed(height_up);
Controller1.ButtonDown.pressed(height_down);
Thank you
