I just started using snapCAD this summer and have created the robot in 3 different files in snapCAD. (base/lift/claw) I would like to combine these files to make one whole robot. Is that possible or do I have to start from the beginning again?
You should be able to go into SnapCAD, create a new model, then under “Multipart>Import Model…” select one of your files. Repeat 2 more times.
Then, in the treeview (on the left side) they should appear under “Document” and you can drag them into the main model.
