The competition is on RIGHT NOW starting in about 5 minutes
Any last minute advice?
Check your robot over before every match.
At the very least make an auton to score the point on your tile.
motors=127;
waitms(500)
motors=0
Talk to your alliance partners
In the semi finals
Thanks
Tabor is right, check your bot first, and have at least a 1pt autonomous. Many teams do not even have an autonomous. We have a 4pt and 6pt for each starting tile(for now);)
If you make it to elimination rounds, try to find an alliance partner that works well with your robot. You need a robot that can build Skyrise sections quickly, and a rapid cube bot. If both can only build Skyrise sections or only cube quickly you won’t compete as well as a good skyrise/cube alliance.
Good Luck!! Let us know how you finish.
