Competition square exact size
We recently borrowed some unofficial soft-tile type squares and put together a 6 X 6 tile competition field, which came out about 4 inches short of 12 ft. How does this compare with the actual regulation playing field? Is it exactly 12 feet across when you measure from wall to wall?
If you’re just tryin to run some autonomous programs that score goals, I think your calculations will be somewhat accurate towards standard size. concerning the ramp and autoloaders, though, i would figure out how far you’re off. Sorry i dont know the info you need
We have found the “Elevation field specs PDF” to be bang on size wise. The ‘glass’ is on the inside of the walls.
Download and read all of the specification drawings as they contain absolutely essential info.
Finally located the diagram we need. Should have followed the instructions!
