Compiler process has timed out
I keep trying each fix I find for this error message when downloading. If anyone else has had this problem any help would be greatly appreciated.
I just turn the radio data on and off again, if that does not work then you can exit out of vex code and try again
Is it happening with wired or wireless setup?
Which programming environment do you use (VexCode, PROS, RobotMesh)?
Do you have any spaces or non-alphanumeric characters in the program path?
Its happening with a wired setup, I use VexCode and theyre are no characters that would be uncompatiable.
Have you tried the project on another computer ? Same result ? Either way, send me the project and I will check it.
sorry for not responding but im pretty sure its just the computer, its worked on other devices so i assume its that.
We are getting the exact same error.
No special characters.
Wired.
Multiple brains AND computers (including both Windows OS and Chrome OS)
Did anyone find a solution to this? We’re having the same problem. (but with VEXcode V5)
This just says to wait a minute and try again. Which isn’t working. And we have switched computers, which hasn’t helped.
It works with block code, but not with text.
