Hi guys,
I’m trying to write a selector for the color of ball that will be ejected by the pooper using a potentiometer. I works by using a boolean, poopColor, that is set to true for ejecting red balls and blue for ejecting blue balls. However, the potentiometer keeps returning a value of 10 and nothing else. Does anyone know the cause of this issue?
Halp ples, thanks
/* Module: main.cpp */
/* Author: C:\Users\Justin */
/* Created: Fri Feb 05 2021 */
/* Description: V5 project */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// LeftFrontDrive motor 1
// LeftRearDrive motor 2
// RightFrontDrive motor 3
// RightRearDrive motor 4
// LeftIntake motor 5
// RightIntake motor 6
// Controller1 controller
// TopMotor motor 7
// BottomMotor motor 8
// ballSorter optical 9
// ejectorSelector pot A
#include "vex.h"
using namespace vex;
competition Competition;
double pi = 3.149265359; //creates a pi variable
//Declaring all movement functions
void spinDrivetrain(void){ //moves drivetrain motors for an undetermined distance
LeftFrontDrive.spin(vex::directionType::fwd , Controller1.Axis3.value() + Controller1.Axis1.value() , velocityUnits::pct);
LeftRearDrive.spin(vex::directionType::fwd , Controller1.Axis3.value() + Controller1.Axis1.value() , velocityUnits::pct);
RightFrontDrive.spin(vex::directionType::fwd , Controller1.Axis3.value() - Controller1.Axis1.value() , velocityUnits::pct);
RightRearDrive.spin(vex::directionType::fwd , Controller1.Axis3.value() - Controller1.Axis1.value() , velocityUnits::pct);
void spinManipulatorsFwd(void){ //spins the intake and magazine motors forward
RightIntake.spin(vex::directionType::fwd , 100 , velocityUnits::pct);
LeftIntake.spin(vex::directionType::fwd , 100 , velocityUnits::pct);
TopMotor.spin(vex::directionType::fwd , 100 , velocityUnits::pct);
BottomMotor.spin(vex::directionType::fwd , 100 , velocityUnits::pct);
void spinManipulatorsRev(void){ //spins intake and magazine motors backward
RightIntake.spin(vex::directionType::rev , 100 , velocityUnits::pct);
LeftIntake.spin(vex::directionType::rev , 100 , velocityUnits::pct);
TopMotor.spin(vex::directionType::rev , 100 , velocityUnits::pct);
BottomMotor.spin(vex::directionType::rev , 100 , velocityUnits::pct);
void spinMagazineFwd(void){ //spins magazine forwards
void spinMagazineRev(void){ //spins magazine backwards
void spinIntakesFwd(void){
void spinIntakesRev(void){
void stopDrivetrain(void){ //stops drivetrain w/ brake Type coast
LeftFrontDrive.stop(coast);
LeftRearDrive.stop(coast);
RightFrontDrive.stop(coast);
RightRearDrive.stop(coast);
void brakeDrivetrain(void){ //stops drivetrain with brake Type brake
LeftFrontDrive.stop(brake);
LeftRearDrive.stop(brake);
RightFrontDrive.stop(brake);
RightRearDrive.stop(brake);
void stopManipulators(void){ //stops all manipulators
TopMotor.stop(coast);
BottomMotor.stop(coast);
RightIntake.stop(coast);
LeftIntake.stop(coast);
void poop(void){
double distanceToTurns(double Distance){ //converts distance IN INCHES to the number of turns needed to reach that distance.
double circumference = 4 * pi;
double rotations = Distance/circumference;
return rotations;
bool robotStuck(){ //checks to see if the robot is stuck by comparing whether or not a motor is spinning with whether a motor is supposed to be spinning
bool isStuck = false;
if(LeftFrontDrive.isDone() != true && LeftFrontDrive.isSpinning() != true){
wait(0.5 , seconds);
isStuck = true;
if(LeftRearDrive.isDone() != true && LeftRearDrive.isSpinning() != true){
isStuck = true;
if(RightFrontDrive.isDone() != true && RightFrontDrive.isSpinning() != true){
isStuck = true;
if(RightRearDrive.isDone() != true && RightRearDrive.isSpinning() != true){
isStuck = true;
return isStuck;
void setDrivetrainSpeed(double Velocity){ //set the motor speed as a percentage out of 100%
Brain.Screen.print("setDrivetrainSpeed called");
Brain.Screen.newLine();
LeftRearDrive.setVelocity(Velocity , pct);
LeftFrontDrive.setVelocity(Velocity , pct);
RightRearDrive.setVelocity(Velocity , pct);
RightFrontDrive.setVelocity(Velocity , pct);
void moveDrivetrainFor(double Distance){ //moves drivetrain a certain distance IN INCHES
LeftFrontDrive.rotateFor(distanceToTurns(Distance) , rev , false);
LeftRearDrive.rotateFor(distanceToTurns(Distance) , rev , false);
RightRearDrive.rotateFor(distanceToTurns(Distance) , rev , false);
RightFrontDrive.rotateFor(distanceToTurns(Distance) , rev , true);
if(robotStuck() == true){ //if robot is stuck then wait 0.25 seconds
wait(0.25 , seconds);
if(robotStuck() == true){ //if robot is still stuck, then stop drivetrain
brakeDrivetrain();
stopDrivetrain();
wait(1 , seconds);
void turnDrivetrainFor(double degrees){ //turns the drivetrain a set number of degrees, with the degrees increasing in a counterclockwise direction
double robotCircumference = 17.5 * pi; //converts the robot's radius into a circle of x circumference
LeftFrontDrive.rotateFor(-1 * distanceToTurns(degrees * robotCircumference / 360) , rev , false);
LeftRearDrive.rotateFor(-1 * distanceToTurns(degrees * robotCircumference / 360) , rev , false);
RightRearDrive.rotateFor(distanceToTurns(degrees * robotCircumference / 360) , rev , false);
RightFrontDrive.rotateFor(distanceToTurns(degrees * robotCircumference / 360) , rev , true);
brakeDrivetrain();
stopDrivetrain();
wait(1 , seconds);
void pre_auton(void) {
vexcodeInit();
Brain.Screen.clearScreen();
ballSorter.setLightPower(100 , pct);
ballSorter.setLight(ledState::on);
/* Autonomous Task */
/* This task is used to control your robot during the autonomous phase of */
/* a VEX Competition. */
/* You must modify the code to add your own robot specific commands here. */
void auton(void) {
spinIntakesFwd();
setDrivetrainSpeed(30);
moveDrivetrainFor(16);
turnDrivetrainFor(105);
moveDrivetrainFor(24);
spinMagazineFwd();
wait (1 , seconds);
stopManipulators();
spinMagazineFwd();
stopManipulators();
spinMagazineFwd();
stopManipulators();
moveDrivetrainFor(-5);
//vexcodeInit();
// Insert autonomous user code here.
/* User Control Task */
/* This task is used to control your robot during the user control phase of */
void usercontrol(void) {
bool poopColor;
//vexcodeInit();
if(ejectorSelector.angle(degrees) < 115){
poopColor = true; //ejects red balls
Brain.Screen.print("true");
if(ejectorSelector.angle(degrees) > 115){
poopColor = false; //ejects blue balls
Brain.Screen.print("false");
while (1) {
// This is the main execution loop for the user control program.
// Each time through the loop your program should update motor + servo
// values based on feedback from the joysticks
//moves drivetrain
Brain.Screen.printAt(125 , 60 , "%f" , ejectorSelector.angle(degrees));
//Brain.Screen.printAt(125 , 70 , "%f" , ballSorter.color());
wait (1,seconds);
if (poopColor == true){
if(/*ballSorter.hue() >0 && ballSorter.hue() < 15*/ballSorter.color() == red){
if(ballSorter.isNearObject() == true){
poop();
wait(1 , seconds);
else if(poopColor == false){
if(/*ballSorter.hue() > 180 && ballSorter.hue() < 240*/ ballSorter.color() == blue){
poop();
wait(1 , seconds);
while(Controller1.Axis3.value() > 10 || Controller1.Axis3.value() < -10 || Controller1.Axis1.value() > 10 || Controller1.Axis1.value() < -10){
spinDrivetrain();
while(Controller1.ButtonR1.pressing()){
spinManipulatorsFwd();
spinDrivetrain();
while(Controller1.ButtonR2.pressing()){
spinManipulatorsRev();
spinDrivetrain();
while(Controller1.ButtonL1.pressing()){
spinMagazineFwd();
spinDrivetrain();
while(Controller1.ButtonL2.pressing()){
spinMagazineRev();
spinDrivetrain();
while (Controller1.ButtonX.pressing()){
spinIntakesFwd();
spinDrivetrain();
while (Controller1.ButtonB.pressing()){
spinIntakesRev();
spinDrivetrain();
stopManipulators();
}//spins intakes and magazine forwards
spinDrivetrain();
//spins intakes and magazine backwards
spinDrivetrain();
spinMagazineFwd();
spinMagazineRev();
//spins intakes forwards
spinIntakesFwd();
spinDrivetrain();
spinIntakesRev();
spinDrivetrain();
while (Controller1.ButtonA.pressing()){
poop();
spinDrivetrain();
// Insert user code here. This is where you use the joystick values to
// update your motors, etc.
// prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods.
// Run the pre-autonomous function.
pre_auton();
Competition.autonomous(auton);
// Prevent main from exiting with an infinite loop.
while (true) {
wait(100, msec);
int main() {
vexcodeInit();
for{
if(Controller1.Axis3 > 10){
LeftFrontDrive.spin(fwd);
LeftRearDrive.spin(fwd);
