confirmed bug in modkit???
Problem:
robot is randomly ‘skipping’ over commands during an autonomous run.
Background:
We had to move beyond using the ‘drive base’ for autonomous. We are using individual motor control.
To do so, we set a variable, RT in this case which stands for ‘right turn’.
We then broadcast ‘RT’ which is received by the left wheel motor.
It then does a simple calculation to convert the variable (45 degree turn in this case) to the required # of motor degrees needed.
We then use a small wait statement to give the robot enough time to complete the movement before continuing.
Proposal:
We think it’s not setting the variable in enough time, and since the variable’s initial value is zero, it essentially ‘skips’ the movement command.
Solution:
put a very small wait after the variable (.05 second) to allow it to fully set
Notes:
We’ve run this a few hundred times and were ready to burn the robot with fire before we figured this out.
The variable ‘skipped’ seems to float depending if you use a fresh battery or not.
The problem affects more than 1 robot.
Can you guys confirm/comment on this problem?
