Console Error Compiling V5 C++
Hi - I was doing some light dressing-up/formatting my code . When I went to compile I got a very strange error in the console (below)
I tried re-creating the file, rebooting PC, commenting out entire code, nothing seems to change in that I get the same error.
Any thoughts are appreciated! Thanks
test .vex (14.5 KB)
08:40:08 -- info -- changed directory: C:/Users/John/AppData/Local/VEX Coding Studio/VEX Coding Studio/sdk/user/
08:40:08 -- info -- C:/Users/John/AppData/Local/VEX Coding Studio/VEX Coding Studio/sdk/user/
08:40:08 -- info -- file removed: C:/Users/John/AppData/Local/VEX Coding Studio/VEX Coding Studio/sdk/user/cxx.o
08:40:08 -- info -- clang version 5.0.1 (tags/RELEASE_501/final)
Target: thumbv7-none--eabi
Thread model: posix
InstalledDir: C:\Program Files (x86)\VEX Robotics\VEX Coding Studio\node_modules\@modkit\modkit-compiler-binaries-windows\clang\bin
 "C:\\Program Files (x86)\\VEX Robotics\\VEX Coding Studio\\node_modules\\@modkit\\modkit-compiler-binaries-windows\\clang\\bin\\clang.exe" -cc1 -triple armv7-none--eabi -emit-obj -disable-free -disable-llvm-verifier -discard-value-names -main-file-name cxx_entry.cpp -mrelocation-model static -mthread-model posix -mdisable-fp-elim -fmath-errno -no-integrated-as -mconstructor-aliases -nostdsysteminc -target-cpu generic -target-feature +soft-float-abi -target-feature -fp-only-sp -target-feature -d16 -target-feature +vfp3 -target-feature -fp16 -target-feature -vfp4 -target-feature -fp-armv8 -target-feature +neon -target-feature -crypto -target-feature +strict-align -target-abi aapcs -mfloat-abi soft -v -dwarf-column-info -debugger-tuning=gdb -ffunction-sections -fdata-sections -coverage-notes-file "C:\\Users\\John\\AppData\\Local\\VEX Coding Studio\\VEX Coding Studio\\sdk\\user\\cxx.gcno" -nostdinc++ -resource-dir "C:\\Program Files (x86)\\VEX Robotics\\VEX Coding Studio\\node_modules\\@modkit\\modkit-compiler-binaries-windows\\clang\\lib\\clang\\5.0.1" -D _LIBCPP_HAS_NO_EXCEPTIONS -D _LIBCPP_HAS_NO_THREADS -D VexV5 -I . -I ../clang/7.0.0/include -I ../vexv5/include -I ../vexv5/gcc/include -I ../vexv5/gcc/include/c++/4.9.3 -I ../vexv5/gcc/include/c++/4.9.3/arm-none-eabi/armv7-ar/thumb -I ../modkit -internal-isystem "C:\\Program Files (x86)\\VEX Robotics\\VEX Coding Studio\\node_modules\\@modkit\\modkit-compiler-binaries-windows\\clang\\lib\\clang\\5.0.1\\include" -internal-isystem include -Os -Wno-unknown-attributes -Werror=return-type -Wall -std=gnu++11 -fdeprecated-macro -fdebug-compilation-dir "C:\\Users\\John\\AppData\\Local\\VEX Coding Studio\\VEX Coding Studio\\sdk\\user" -ferror-limit 19 -fmessage-length 0 -fallow-half-arguments-and-returns -fno-rtti -fshort-enums -fno-signed-char -fno-threadsafe-statics -fobjc-runtime=gcc -fdiagnostics-show-option -vectorize-loops -vectorize-slp -o cxx.o -x c++ cxx_entry.cpp
clang -cc1 version 5.0.1 based upon LLVM 5.0.1 default target i686-pc-windows-msvc
ignoring nonexistent directory "C:\Program Files (x86)\VEX Robotics\VEX Coding Studio\node_modules\@modkit\modkit-compiler-binaries-windows\clang\lib\clang\5.0.1\include"
ignoring nonexistent directory "include"
#include "..." search starts here:
#include <...> search starts here:
 ../vexv5/include
 ../modkit
End of search list.
08:40:08 -- info -- make process failed with return code: 1
could this be a ‘linking’ error I’ve seen mentioned?
Hi I downloaded your program and got the same error as you on the first compilation. I then deleted the word ‘void’ in every function and it compiled. Hope this helps.
(Edit: In general, all errors that are not highlighted on the IDE are usually to do with function declaration, parameters or calling in my experience)
WOW AKBAB - nice find! I did know this!
I’m sorry, I’ve deleting void everywhere and not having any luck. Would you mind uploading your so I can see what I’m missing?
The problem is you have a forward ref to functions like this.
void aGrab(int, double, bool);     //CLAW BY ABSOLUTE DISTANCE
and then define the function with a different signature.
void aGrab(double deg, int s, bool b){
    GrabberArm.rotateTo(deg, vex::rotationUnits::deg,s, vex::velocityUnits::pct,b); //This command is blocking so the program will wait here until the right motor is done.
    vex::task::sleep(20);
}//end eGrab
so linker is looking for function defined with int, double, bool but yours is different.
DOH! I see that! Corrected - MANY THANKS!!
@poodlebytes sorry for the misinformation! Turns out I’d commented out some offending lines of code, deleted those voids and THEN it had compiled. Anyway glad you found the fix!
it’s OK - I appreciate your help!! Best 2U!
I’m having problem with a c++17 and I’m not very good at programming so any help would be nice
I’m not a coder, but you should start a new thread instead of reviving an old one
