I cannot for the life of me figure out how to control a LED from Robot C. I have done it in EasyC.
I have the LED hooked up to a extension positive to red and negative to black. All the LED does is stay on. Am I doing this correctly?
Been a while since I posted!
Thanks,
Kyle
Quazer answered:
[INDENT]**Hey Kyle,
If you are hooking the LED to red(+) and black(-) then it will be constantly powered, as you are seeing. The control signal is the white wire, so you need to wire the LED from white-to-red or from white-to-black (observing correct polarity, of course).
If you wire it white-to-red, then you’ll have to write a ‘0’ to the port to turn the LED on. If you wire it white-to-black, then a ‘1’ will turn it on.
If this is a high power LED, then you might need to add a transistor to get any significant brightness. The control signal (white) can only drive around 4 or 5 mA.
Cheers,
This works great! Thanks Dean!
