Control motors together in python
We are doing a competition for our robotics class. We need to have autonomous and driver control. I can have the joystick control during the user control period. I use the programming example that uses individual left and right motor commands to match the position of the joysticks to the motor speed. However, I can’t turn accurately in autonomous without the Drivetrain command. So is there a way to have tank joystick control and be able to do autonomous?
As for any programming question, please post the code that you already have.
def pre_autonomous():
    # actions to do when the program starts
    arm.set_timeout(2, SECONDS)
    arm.set_stopping(HOLD)
    claw.set_timeout(2, SECONDS)
    claw.set_stopping(HOLD)
    arm.set_velocity(30, PERCENT)
    claw.set_velocity(30, PERCENT)
def autonomous():
    #actions to do when the autonomous starts
    left_motor.spin_for(REVERSE, 2, TURNS)
    right_motor.spin_for(FORWARD, 2, TURNS)
def user_control():
    #actions to do when the user_control starts
    while True:
        left_motor.set_velocity(controller_1.axis3.position(), PERCENT)
        right_motor.set_velocity(controller_1.axis2.position(), PERCENT)
        left_motor.spin(FORWARD)
        right_motor.spin(FORWARD)
        wait(5, MSEC)
        if controller_1.buttonL1.pressing():
            arm.spin(FORWARD)
        else:
            arm.stop()
            if controller_1.buttonL2.pressing():
                arm.spin(REVERSE)
            else:
                arm.stop()
                if controller_1.buttonR1.pressing():
                    claw.spin(FORWARD)
                else:
                    claw.stop()
                    if controller_1.buttonR2.pressing():
                        claw.spin(REVERSE)
                    else:
                        claw.stop()
                    wait(5, MSEC)
    wait(5, MSEC)
# create competition instance
comp = Competition(user_control, autonomous)
pre_autonomous()
autonomous()
user_control()
For the turn functions, just type in the parameter: wait=false.
For example, using your program:
left_motor.spin_for(REVERSE, 2, TURNS, wait=false)
I would recommend you do that for only the first turn command in a row of functions. Hope this helps.
okay thanks!
20 characters
