Just opened a new kit. As soon as I turned it on and tried to connect it via Bluetooth to a brain, I get a red screen that says Alert and Cannot use Bluetooth. Brain shows it is connected.
I’ve turned off/on, several times, checked for and run firmware updates, pressed the rest button on the back of the remote, checked smart cable connections, etc.
Bluetooth is not allowed when using competition control.
If the pause symbol is shown constantly on the controller, it probably has a damaged competition port, this can happen occasionally if a smart cable is accidentally plugged into the 8-pin RJ45 port instead of the 4-pin smart port.
Unless there is some obvious physical damage to the pins on the competition port (ie. bent pins or something like that), then no. But if it’s a new controller you should be able to get an RMA and exchange it. Call vex support, https://www.vexrobotics.com/contact-us#offices
I found my used V5 controller started to show this message this week, too. Pressing the dismiss key, the alert will go away but will come back in few second. Is the controller broken?
Is the controller switched to VEXnet or Bluetooth ?
When exactly does the message show ? Usually that message only shows when the V5 radio is switched to bluetooth and then connected to field control (BLE is not allowed to be used for standard matches)
