Controller Question?
i made an easyC program to display the number that channel 3 on the controller gives. when the joystick is centered its 31, joystick down: 175 and when the joystick is up its 31,
i just got this controller so it shouldn’t be broken
whats going on?!?!!?!?!?!?!?:confused: :confused: :confused: :mad:
That does not sound good… What happens if you try Channel 1 or 2 or 4?? Do they show ~0 to ~127 to ~255 ???
i will try those tommorow, im pretty tired today
i have remade the program to include all channels, i reset the controller by doing what it said in the inventors guide. all the other channels:
channel 1 works
channel 2 works
channel 3 same problem
channel 4 works
channel 5 works
channel 6 works
this is really wierd:confused:
Try adjusting the trim on channel 3.
I agree, that seems like the only thing that is User Adjustable that could effect the output.
I don’t know if the Trim will adjust that far to give the Numbers that basicxman is seeing, but there is not much else he can do…
