Controller Screen PROS
Is anyone able to get information to the controller screen using PROS. We can get to the brain screen, but not the controllers. Can anyone help.
There is a limit of one message every 50ms to the controllers. Last I checked, VCS enforces this delay for you, but RMS and PROS do not. So if you are trying to clear your controllers’ screen then write something immediately after, the clear command will work but the write command will be ignored.
If your messages are already spaced out but are still having problems, you should post the problem code so someone familiar with PROS can take a closer look.
