Controlling Talon SR using RobotC? Unofficial
So in ROBOTC when you set the motor type it configures the pwm signal that will be sent. Luckily the talon uses the same 1-2 ms pwm signal as all the vex motors so you should have no issue setting the motor controller as a 393 motor. Let me know if you have any other questions.
Response to
https://vexforum.com/t/controlling-talon-sr-using-robotc/35920/1
http://ctr-electronics.com/Talon_User_Manual_1_1.pdf
@johnsbla000
