is there a quick way to convert the files quickly without having to manually copying the entire code again?
because we have cortex/joystick issues and we would like a copy of our code in easyC Pro in case we have to do an emergency swap at the competition
thanks in advance
You’d have to convert your code into “C” code (see tutorial 13 and 14) and import the .c files into easyC pro. Then you will have to change all your motor and joystick functions are they are not compatible between the two controllers.
Is problem physical or do you need software help?
