Cortex Power Supply
I’d like to set up a demo robot in a display case and I would prefer not to use batteries to keep it running. Can anyone recommend a power supply that I can use to power the Cortex?
Something like this? http://m.ebay.com/itm/AC-to-DC-7-5V-1A-1000MA-Transformer-Charger-Power-Supply-5-5x2-1-2-5x0-7-Adapter-/361361652353?nav=SEARCH
It’s 7.5vdc but only 1 amp. Not sure what exactly you are running or if you might need something more powerful. You will though have to solder a battery connector onto any power supply.
Thanks Kevin
I also found this: Wall Adapter Power Supply - 9V DC 650mA .
The specs on the Cortex say 7.2 volts nominal, 5 to 12 volts min/max with 150mA for Controller & Receiver plus Motors, Servos & VEXnet.
I found the plug here: 7.2V Connector Tamiya Type Set but I hope I can by that at a local hobby store.
I would hate to harm a Cortex so if any EE’s don’t agree with my findings then let me know. :slight_smile:
Without motor a 1A power supply should be ok. If you have motors then you will need much more, remember a motor will draw >4A briefly when starting.
Others have recommended this type of unit in the past.
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_2102545_-1
Old PC power supplies can be hacked to make lovely high current 5V and 12V power supplies. The 5V is a bit on the low side for this purpose, and the 12V a bit on the high side… but the price is right.
