Hello! I apologize if this problem already listed in the forum but my searching skills are lacking at this time
We’re using RobotC programming, Cortex, and the older Vexnet keys.
The cortex and joystick have been updated to the latest firmware.
There is a simple joystick program loaded using 4 motors:
#pragma config(Motor, port2, right1, tmotorVex269_MC29, openLoop, reversed)
#pragma config(Motor, port3, left1, tmotorServoContinuousRotation, openLoop)
#pragma config(Motor, port4, right2, tmotorVex269_MC29, openLoop, reversed)
#pragma config(Motor, port5, left2, tmotorServoContinuousRotation, openLoop)
task main ()
while(1 == 1)
motor[left1] = (vexRT[Ch2] + vexRT[Ch1])/2; // (y + x)/2
motor[right1] = (vexRT[Ch2] - vexRT[Ch1])/2; // (y - x)/2
motor[left2] = (vexRT[Ch2] + vexRT[Ch1])/2; // (y + x)/2
motor[right2] = (vexRT[Ch2] - vexRT[Ch1])/2; // (y - x)/2
The software inspection lists this:
Communications Link: USB-to-Serial Link (COM5) from Cortex to PC
Standard Firmware File Names:
VEXNET Joystick: .\Firmware\JOY_V4_23.BIN
VEX Cortex Master CPU Firmware: .\Firmware\CORTEX_V4_23.BIN
VEX Cortex CPU Firmware: .\Firmware\VEX_Cortex_1027.hex
VEXnet Joystick Integrity:
No joystick connection. Direct USB-to-Serial connection to PC.
Joystick State: No joystick. USB-to-Serial
Cortex Master CPU Integrity: Value Status
Firmware Version: 4.23 Up to Date
Main Battery: 7.6V Good (>6.5V)
Backup Battery: 9.2V Good (>8.7V)
Team Name: “9965A” OK
Cortex User CPU Integrity: Value Status
Cortex USER CPU not responding. Firmware may need to be reloaded.
So, we are able to operate the robot both tethered and using the keys. The Robot LED first starts out solid green and then changes to a slow blinking red. We can still run the robot with the joystick ok most of the time for a long period of time but sometimes we lose connection. Any thoughts?
I’ve reloaded the firmware a ton of times and still get the same inspection comments. We compete in a few weeks and want to work out the bugs before loading our competition program.
Thanks for the help!
