Create a Task
Is there a way to create tasks in robot c graphical
To my knowledge, no. Try this program though, it may work as I have modified it manually as a text file. Change the file extension to .rbg and see if it works.
I changed the code without changing the blocks.
Graphical002.vex (3.63 KB)
Not sure how the variable (code above) would work. I am trying to make an e-stop task button that would run inside of a program. Task would look like this:
Create a task called e-stop (if button pressed stop all tasks)
Then write a program to do what our program would do, but inside of the program there would be a line at the start of the program that would say start e-stop. if the button were pressed it would start the e-stop.
How would I do this below (In RobotC Graphical)
task e_stop()
while(true)
if(SensorValue(e_stopBtn) == 1)
stopAllTasks(); // ends the program and all tasks including task main.
wait1Msec(10); // prevents the current task from using majority of available CPU capacity
task main()
startTask(e_stop); // initiates the e-stop task which will run simultaneously
while(true)
if(SensorValue(sonar) <= 10)
motor[rightMotor] = 32;
motor[leftMotor] = -32;
else
motor[rightMotor] = 127;
motor[leftMotor] = -127;
Vex IQ had a topic related to this: http://www.vexiqforum.com/forum/viqc-ringmaster-2017-2018-game/31652-re-robotc-graphical-multitasking
There really is no need for all that complexity. You have a single while(true) loop for the main code. Just check inside that loop and change while(true). For example,
bool eStop = false;
task main() {
   while(eStop != true){
      if(SensorValue(sonar) <= 10) {
      else {
      if(SensorValue(e_stopBtn) == 1) {
         eStop = true;
      wait1Msec(10);
