Creating a file in PROS
I followed all the steps in the PROS website and am attempting to create a file using atom. I have installed the PROS-atom3 package but when I try to create a new project, nothing shows up. Gif attached below. If any other information is needed, let me know.
Thanks
What instructions did you follow?
https://pros.cs.purdue.edu/v5/getting-started/macos.html
I did not follow those instructions, but I just did them and it still doesn’t work.
Your video suggests to me that the CLI may not be set up properly. To see if it is, can you run
prosv5 --version
in the terminal? You should see the version of the PROS CLI printed.
That was it. Thank you
For future readers, what did you do to make it work?
I went to the Pros website and redownloaded CLI.
