Creating an integer in robot mesh python
Could someone send an example of creating an interger? I know how to make a variable, I usually say (name of variable) = None
But when I make something equal to a number
Ex:
Distance = 1
All it does is make distance ==1 but it’s just a variable and not an integer. Please help on making something an integer. It’s easier with cpp because you can say-
int Distance = 1
I am pretty sure just setting something to a number allocates whatever memory it needs and classifies it as a (whatever number type). So your code technically does make an integer. An integer is a type of variable.
https://www.programiz.com/python-programming/numbers
https://www.tutorialspoint.com/python/python_numbers.htm
So, you could argue that it is easier with Python (I still prefer C++).
In python, variables become initialized whenever you use them in the code. (i.e. you don’t have to “create” or initialize the integer, it will create its self)
EDIT: Sniped by @trontech569, his explanation was better.
What’s the difference between making distance equal to one, and creating an integer called distance? What are you trying to do that’s not working with this/how is this different from the behaviour you were expecting?
What I’m trying to do is something like this
Distance = 1
While true:
If joystick.buttonA.pressing():
Distance = Distance + 1
This line should be that whenever I press A, the distance variable should go from 1-2 and every time I press it, the variable increases by 1, but this isnt working and instead it’s just saying that the variable distance is LITERALLY equal to Distance + 1
That snippet looks okay to me - could you post the exact code you’re having trouble with (remembering to wrap it in [code]...[/code] tags for formatting)?
Also, I’m not quite sure what you mean by
could you expand on this?
You might need to use some kind of sleep function, so it only has enough time to add the number once. like this:
Distance = 1
while True:
     if joystick.buttonA.pressing():
         Distance = Distance + 1 #Distance += 1 does the same thing
         sys.sleep(0.2)
Variables are containers for storing data values. Unlike other programming languages, Python has no command for declaring a variable. A variable is created the moment you first assign a value to it.
Reminder, that if you use a variable, always declare it ahead of time and set it equal to SOME value. An accidental usage when it’s undeclared can cause undesired results.
