After months of input, designing, and CAD’ing, we have finished the second generation charger; Z-Charge. We are offering two versions of this new station, a full feature version, and a more budget-friendly version.
Basic Version Features
-12 Smart Charger / 7.2V Robot Battery NiMH 3000mAh Capacity
-All new sleek design
-Compact and travel-friendly
-All batteries and chargers can be stored in the case
-Helps make packing for tournaments easy
-Makes it easy to use all your chargers
-Never worry about running out of plugs for your chargers
-Custom fit heavy duty travel case
Pro Version Features
-Everything in the Basic Version
-Pre-Installed LED Charging Bay Under-glow
-Integrated LCD Voltmeters to display real-time battery charge (represented by the purple rectangles)
-Team Name / Number on the sides as well as on the travel case
-Castors
-AAA Charger Easy Mount (not shown)
Z-Charge is appx. 20.5" long, 13.5" wide, and 9" tall (without castors).
The toolbox will be painted black.
Pricing
Basic Version - $300.00
Pro Version - $450.00
*Shipping charges are not included
Due to time we can only make a limited quantity of these charging stations. You can submit an order through our website: team323z.com/z-charge. If you are interested in receiving one of these charging stations, we suggest you get your name down soon.
Can you try to re-post the pic of your charging stating? It looks like the link in broken. Here’s one I put together for the team that can hold 12 batteries that are connected to power strips in the center (hidden in the middle of the cart) and then I added another power strip on top for computers and phones with the USB ports. Plus it has a fan to help pull the heat out of the center core to keep the temp down from the chargers/batteries. Rolls on casters and everything is powered off of one single plug. Thanks for your v1 design as I used that pic to help give me a couple of ideas, but would be curious to see your v2.
Boss, I could make another one for you if you are interested. Only took me a few hours (besides letting the paint coats dry) to build this one a couple of weeks ago. I would just need to know your color selections if you want it painted as well as any team number info. I can assemble it all (except for your chargers) and then you would need to plug all of them in to the internal power strips. Let me know.
